will the iron 6.0l heads work on an ls1?
Old 09-05-2010, 03:26 PM
ricknbird350's Avatar
Default will the iron 6.0l heads work on an ls1?
i am putting an ls1 in a 00 gmc truck (had a 6.0l) and i wanna use the original iron heads 317? i think? to drop compression so he wont have to run premium fuel. will those heads work with the smaller bore and stock ls1 head gaskets? and what do you think the compression would be?
Old 09-08-2010, 10:10 PM
arent the 317 heads for 4 inch bore? just wondering if they will work ok with the smaller 3.9 bore
Old 09-08-2010, 10:26 PM
Mike454SS's Avatar
317 heads are not on a 2000, and are aluminum.
2000 6.0 heads are iron, and are a different casting number.
Old 09-12-2010, 01:17 AM
one fast zo6's Avatar
yes they will work.
Old 09-12-2010, 02:04 AM
01ssreda4's Avatar
Different bore sizes. No they wont work.
Old 09-13-2010, 12:11 AM
Mighty Whitey's Avatar
iron heads on an Aluminum block??
sounds like the old cadillac HT4100 from the 80's...
aluminum 317's are going for so cheap these days, I'd just pick up a set of those, just so I would have to lug around those heavy *** iron heads.
Quick Reply: will the iron 6.0l heads work on an ls1?
