LS1 water pump with truck acc's?
Old 09-13-2010, 05:39 PM
ss.slp.ls1's Avatar
Default LS1 water pump with truck acc's?
Has anyone used a LS1 water pump with the LM7/LQ4/9 truck acc bracket and acc's?
Old 09-13-2010, 05:52 PM
Jon@Texas-Speed's Avatar
It will not work. The truck accessories sit too far out.
Jon
Old 09-13-2010, 05:54 PM
ss.slp.ls1's Avatar
Jon
I know the the offset of the belt is different, but I thought that the large bell on the LS1 water pump would still make it feasable...
Old 09-13-2010, 05:55 PM
vandejr's Avatar
Never say Never. billet spacers like i did.
http://www.ls1truck.com/forums/sale-...k-engines.html
Old 09-13-2010, 06:00 PM
ss.slp.ls1's Avatar
Originally Posted by vandejr
i did. especially cause the neck was in the way of my tb and u have to space it out with billet spacers like i did.
Yeah, that's why I am asking if you can change only the pump. Those spacers look nice, where did you get them? Did you just used two sets (4) water pump gaskets and longer bolts? Did you still torque it to 22 ft.lbs?
Old 09-13-2010, 06:04 PM
vandejr's Avatar
pm the guy on the link.red. it comes with the longer bolts and the spacers. u will need the 4 gaskets though.i think i paid 85 or 75 shipped dont remember. It was alot cheapier then changing the whole setup to f-body or c5 accessories.
Not the best pic but thats a ls1 pump with the billet spacer.
Old 09-15-2010, 08:38 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
Or, you could go this route, https://ls1tech.com/forums/new-produ...-270-99-a.html
If you just want the spacer, bolt, washer and belt it would be $62.69 + shipping.
Old 09-15-2010, 11:05 AM
ss.slp.ls1's Avatar
The picture you have is of a L92, not a LQ4, totally different problem. The issue is when you try to bolt on a LS1/LS6 manifold onto a LQ4 the TB will hit the upper radiator hose port on the water pump because it is shaped up and then curves out instead of just coming straight out of the pump like on the LS1 water pump.
Old 09-15-2010, 01:54 PM
LS1TECH Sponsor
Actually, the picture is a 5.3L with a LS2 intake!!! That was the worst case cenerio for fitment. The LS1/LS6 was way better for fit.
The pump is the new GM truck waterpump, and it is a direct fit for the older truck stuff, well, not sure about the upper hose, the waterneck is just off to the side.
Old 09-16-2010, 09:10 PM
11 Second Truck Club
bluecajun5.3's Avatar
depending on which tb, the cable will clear that new style w/p but not a dbw. you can use the ls1 water pump, all you have to do is use a puller to pull the pulley away from the w/p it self.
Old 09-17-2010, 11:08 AM
ss.slp.ls1's Avatar
Excellent news, I think I have one of the new truck water pumps.
Quick Reply: LS1 water pump with truck acc's?
