Alternator problem...help please
Ok found my pos. battery cable loose.When I tightened it up I striped it.Tried to drive it to the parts house but on the way it started cutting out and went dead......I installed a new battery then found out I fried the alternator.I had it rebuilt today and it wont charge??? The guy that rebuilt it tried it on the tester before I left with it so I know the alt. is good.The car is a 2000 z28.! big wire +1 little wire....thanks
exciter wire
checked the exciter wire....got 9.45 going into the plug w/the key on....when i stick the prob in the front side of the plug 0.0 .Then if i wiggle the wire I get voltage to the front side of the plug.I think the wire is broke inside the plug.As 4 the 9.45 reading not sure if i have the metter set right.....i got it on DCV @ 20.0.....can i take the plug apart ???
You can get a new connector off ebay for a decent price:
http://cgi.ebay.com/ebaymotors/ws/eB...d=260234304584
I think the dealer charges $40 for it.
