Noob question
Old 11-21-2010, 01:47 AM
LSJ80R's Avatar
Default Noob question
Hi, Recently finished a 24->58 reluctor conversion on an early ls2. Not sure if the main cap bolts (inner and outer) are reused, seeing as how gm use this tourque to yield thing?
Can someone tell me if i can reuse them or not because new ones are the better part of $500.
Cheers, D.
Old 11-21-2010, 02:08 AM
ANTICOP RAM AIR's Avatar
i have reused them before, the new ones are a certain length, (i cant recall) and they stretch when torqued, you need to measure them and compare them to the new/unused measurement.... then see if there is a "stretched length" i got away with using this method on older builds.. once theyre a certain length untorqued, theyre trash because they wont stretch/hold anymore.. i think im right>>> but its been a while. do you know if they have ever been removed before? you will more than likely be ok if its a stock bottom end but you just never know...
my advice to you... bite the bullet and get new ones, just to be safe... all your power rests on those bolts... good luck bro
