how to hook up tach to 95 camaro
Old 11-23-2010, 05:04 PM
Stingerrr85's Avatar
Default how to hook up tach to 95 camaro
how do i hook up my tach to my 95 ls camaro
Old 11-24-2010, 09:23 AM
Jim85IROC's Avatar
You use the tach output from the PCM. Doing a search, especially on the swap/hybrid forum should give you all the info that you'll need. Most aftermarket tachs need a stronger signal, so you may need to install a pull-up resistor, but that should be discussed in the threads.
Old 11-25-2010, 09:43 AM
crainholio's Avatar
Correctly.
Quick Reply: how to hook up tach to 95 camaro
