Vacum Map?? LQ4
Old 11-27-2010, 10:36 AM
MillsMotorvation's Avatar
Default Vacum Map?? LQ4
Forgive the dumb?? Where are the vacum ports on this truck intake? I see the spot for the brake booster but are there any I missed? It's a 2002 LQ4.
Old 11-27-2010, 08:54 PM
Just tell me where do I get reference for a boost gauge?
Old 11-27-2010, 09:43 PM
Smokinz28's Avatar
the should be a diagram inside your hood.
Old 11-28-2010, 07:15 AM
I did a swap, the engine is in a 1981TTA.
Old 11-28-2010, 09:23 AM
Smokinz28's Avatar
look on your manifold, or behind your throttle plate on your throttle body. you can use most just make sure you use a t fitting
