fast 102
fast 102
Has anybody installed a fast 102/102 with SPOHN solid motor mounts? I want to see how close it is to the cowl. I am thinking of switching from a gmpp to a fast but if it doesnt fit why bother to buy one. Post pics if you can. thanks
I have a ls2 block, ls7 heads and the fast 102 cleared the cowl by about 1/4 of an inch.
The car has the harder prothane mounts but the height should be the same.
I installed the fast with the engine in the car. Upon recently dropping the engine for a stage 2 port on the heads, I found that the intake was hitting the oil pressure sending unit.
I filed off the back edge of the intake to omit the clearance problem.
You may also have to do some adjustments on the front, like top of the water pump.
It's Tight ! but it will fit.
she will fit, we put one on a 2000 ss 416, w/ the spohn solid mounts.
