02 Extensions, do I need them?
Old 12-17-2010, 07:57 AM
masterz28's Avatar
Default 02 Extensions, do I need them?
Do i need those extensions, these....
http://www.ws6project.com/user_stor/...roducts_id=759
Or can i just plug up the pacesetter header ports and weld em shut? Not worry about it? And tune out the code later when i tune the car or will it effect anything?
Old 12-17-2010, 10:35 AM
omarrakeen's Avatar
front or rears?? for the fronts yes you do need them. for the rears it wont hurt anything if you dont put them except the SES light. 24" would hang down so you have to tight it. i say measure how much of wire you need then decide.
EDIT: omg i just read you want to shut O2 bungs? dont do it. get your extensions and use front O2's.
Old 12-17-2010, 05:26 PM
Jon@Texas-Speed's Avatar
Pacesetter sends wire to cut and splice the O2 sensors but I wouldn't recommend it. The plug and play extensions for the fronts are a better choice by far. We have them for $40 for the pair.
Jon
Old 12-17-2010, 07:51 PM
masterz28's Avatar
ok, i will keep em. I have to buy those extensions then. Thanks Jon and Omar.
Old 12-18-2010, 11:51 AM
LSX Mechanic
Damian's Avatar
The front 02's are an absolute must. It's not an option to go without them. The rear 02's you can get rid of.
