Changing Plugs and Wires=PITA?
Old 12-21-2010, 06:07 PM
ArkBird96's Avatar
Default Changing Plugs and Wires=PITA?
So I'm thinking about doing plugs and wires on my Formula. How hard is this? I've heart horror stories about the #8 cylinder. Is this something that I could reasonably expect to do in a day?
Old 12-21-2010, 06:11 PM
Trunion King
bene's Avatar
It's not that hard. You can easily just get under the car and reach for the #8 plugs/wires and change it OR take out the coil packs/braket out and easily accessible on the top.
CayenneRedV6's Avatar
Yeah it can be done in an hour or two if you've done it before. The driver's side is cake and the passenger side is so much easier if you remove the coils.
^Beat me to it.
Old 12-21-2010, 06:13 PM
zracer323's Avatar
Peopple make it seem harder than it is. Just remove the coil packs and its easy
Old 12-21-2010, 06:44 PM
TORCHD 02 TA's Avatar
Drivers side is easy.. For the passenger side, remove the coil pack, and you can get #8 from the top, but it seems a lot of people do it from the bottom
Old 12-22-2010, 07:24 AM
reeperz28's Avatar
first time i did i had limited tools and took three hours second time i did it i had my tools and took an hour and 15 but ya just remove that coilpack frame on pass side
Old 12-22-2010, 08:15 AM
disc0monkey's Avatar
#8 to me is the easiest one on the pass side, i just go from the bottom. gotta take the air off and if the rear bolt is out of the coil packs thats easy too.
