Can I use this setup instead of 2 cats on the car???
I have a 99 camaro SS can I use this setup with out having to buy to cats for the driver side and the passanger side let me know guys?
MAGNAFLOW DIRECT FIT CATALYTIC CONVERTER ASSEMBLY -- 50-state legal; 3-way catalyst style; Flange inlet; 2-1 inlet and single outlet configuration; Y-pipe assembly with one catalytic converter; Ceramic honeycomb catalyst substrate; Round stainless steel casing; Designed to exact original equipment specifications; While the majority of the direct fit catalytic converter products do not require welding, cutting, or bending, limited applications may require additional welding for optimal installation.
Fits: Car, Canada, United States or Mexico Built Vehicle, EFN # XGMXV03.8049, XGMXV03.8051.
Material: Stainless steel
Type: Direct OE replacement
Part#: M6646466
Part#: M6646466
If this is built for your specific year I dnt see an issue with it. I assume you are wanting to stay emissions legal. Cause if you werent id say save your money for a set of longtubes and offroad ypipe and be done with it.
