May be a stupid question
I am going to disassemble my FAST 92 at some point point to have it custom painted. Is all I have to do is unbolt and then bolt it back together? Seems like that is all that would be required but dont wanna screw something up. Tried search couldnt find anything
yep, brand new they come with nuts on the bottom of the intake holding it together. Once you install it you just thread the provided bolts the nuts were threaded to into your heads. Once you take those bolts out it will simply pull apart, be gentle with the seals and you're good to go.
Hope that makes sense and good luck.
