map sensor question
Old 01-19-2011, 08:22 PM
slap(A)hoe's Avatar
Default map sensor question
this may b a stupid question but i dont know so i am gonna ask lol
on the back of theintake where the map sensor hooks up is it ok if u can wiggle the map sensor around ??
Old 01-19-2011, 09:05 PM
Squirts11's Avatar
The only issue that comes to mind would be a possible vacuum leak. If the car is idling/running well, then you're most likely fine.
My map sensor was very loose in my FAST intake, but some sensor safe rtv helped.
Old 01-19-2011, 10:48 PM
slap(A)hoe's Avatar
reason i ask is because i am getting a p0300 code
Old 01-19-2011, 10:59 PM
onslwcavi's Avatar
Well that is a random misfire code. Wouldn't normally be associated with a map issue. The map sensor can be wiggled around minimally, even in a factory intake.
Quick Reply: map sensor question
