gutting cats passing inspection obdII
Old 01-28-2011, 03:27 PM
fastbird02's Avatar
Default gutting cats passing inspection obdII
hello everyone. quick question. if i gut my cats will i fail an obdii test?? i live in MA. and the guy i go to just plugs it in and if it passes, it passes.
Old 01-28-2011, 03:29 PM
metalmilitia606's Avatar
I would imagine you would probably fail. Cats help filter out a lot of the crap that makes you fail tests. I could be wrong though. I live in Ohio we don't have emissions stuff
Old 01-28-2011, 03:33 PM
fastbird02's Avatar
so gutting cats will throw a code?
Old 01-28-2011, 03:44 PM
6speedt/a's Avatar
yes gutting the cat will cause a code in the pcm along with a check engine light. If i where you i would gut them and then get a tune and tune out the rear o2 sensors
Old 01-28-2011, 03:48 PM
bren5666's Avatar
It will probably fail, but if you're lucky it may run clean enough to pass. Where I live in Ohio we still have to be checked.
Old 01-28-2011, 10:09 PM
massls1guy's Avatar
I assume you mean you want to gut the stock cats. Chances are you will break a few of the studs that fasten the cats to the stock exhaust manifolds when you try to remove them. In my opinion the only reason to touch those studs/bolts is to take all the stock exhaust off and replace with a good set of headers and cat back.
