Help with coil wiring harness
Old 02-17-2011, 03:39 PM
hairydog03's Avatar
Default Help with coil wiring harness
I'm in the process of relocating the coils and my dad messed around in the garage and now i'm not sure which harness goes to which coils. Will I have a major problem now with the firing order because I dont know if i'm putting the passenger side harness on the driver side coils.
Old 02-17-2011, 04:22 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Each head's coil bracket has a harness attached to it. They are identical left to right. They connect to the engine harness in the center. It is these engine harness plugs that determine left and right.
Exactly which plugs do you think you have mixed up?
Old 02-17-2011, 04:26 PM
Paul Bell's Avatar
Tell yer pops to find a car with a carburetor on it.
Old 02-18-2011, 02:52 AM
hairydog03's Avatar
Well my problem is I think I may have put the passenger side harness on the drivers side coils b/c of where my dad moved my **** around. I assume that there probably will be an issue with that
Old 02-18-2011, 07:51 AM
Paul Bell's Avatar
Which harness are you talking about? The coil harness that's attached to the coil bracket or the engine harness?
Old 02-18-2011, 11:30 AM
hairydog03's Avatar
The one that attaches to the coil packs
Old 02-18-2011, 11:45 AM
joecar's Avatar
The coil bracket sub-harness on bank2 (RHS, passenger side in USA) usually has a white or black strip on each of the wires.
