5.3 Front drive accessories on ls1?
About to buy an ls1 from an 02 camaro but it does not have any front drive accessories on it. Having trouble locating a package from an fbody. This motor will be going in a 93 mustang coupe. Since 5.3s are so readily available will the front drive accessories from a 5.3 bolt right up to an ls1?
I did some searchign and nothing came up. Thanks for the help.
You can make it work, but it isn't a direct bolt-on solution. You'll essentially have to go through the same steps as you would for mounting a car manifold (LS1/LS6) on a truck motor.
Here is a thread from LS1truck.com that shows how to do it:
http://www.ls1truck.com/forums/showthread.php?t=12719
