Typhoon 96mm intake question
Old 03-12-2011, 05:18 AM
dkiller2135's Avatar
Question Typhoon 96mm intake question
Dkiller2135@yahoo.com
Man I got a deal on this intake. Have the 99 stocker intake currently. I notice this is made for a ls1/ls6 and ls2. Dude said I'd need larger o rings if I use the Original injectors. Make me think it's a ls2. Does it matter will it still fit? Do I need new fuel rails. They seem to come new will high flow rails but I don't have them. If this will fit I'll use it. But I'm not sure about all the differences between the lsx models? I'm hoping to only need gaskets, orings, and latter a 102mm trottle body. Should I need a new mas air sensor for the larger openings. I plan on putting a 220/220 cam in when I do all this. Will stock lifters be ok. The engine only has 90k. All help will be appreciTed.
Old 03-12-2011, 06:50 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I've only heard issues with them.
Old 03-12-2011, 07:18 AM
bayer-z28's Avatar
If it's the LS2 model, it's a 96mm manifold. 102 TB prolly won't fit.
-Yes it will still fit.
-Not sure about the injector o-rings
-That intake uses a solid piece gasket, not the o-rings. Get the one w the green. I've heard those are better.
-Aftermarket fuel rails are needed, SpeedInc Budget fuel rail kit is actually the PP kit that normally comes with that intake.
-You can run whatever MAF you want, but I'd go with an 85mm Delphi unit.
-At 90k, I'd replace the lifters with some Caddy Racing lifters.
-You may need low profile Pan Head valley cover bolts.
Old 03-12-2011, 04:18 PM
Thanks for the straight forward answers. Thats a first for me. I dig the Keith stone pic as well.
Old 03-12-2011, 06:20 PM
bayer-z28's Avatar
^ No prob dude. And thanks.
