243's,799's,317's??? n/a now, f/i later. Help spend my $$.
Old 04-24-2011, 07:18 AM
boostnut's Avatar
Default 243's,799's,317's??? n/a now, f/i later. Help spend my $$.
Not sure what heads to run, looking for some advise. Engine is currently a bone stock LS1 going into a 95 mustang backed by an A4 with a 3200-3400 stall from circle-d. I'm planning on running it n/a initially then going turbo later (could be a year +). Planning on running the stock cam at least while its n/a. So, the 853 really aren't worth putting back on, what should I expect if I run stock 317's without any decking for now? I know the compression #'s will drop from the bigger chambers, is there any real problem here? Anybody have any times or dyno #'s from running stock sized 317's on a stock bottom end LS1? The reasons I'm leaning this way are price and compatibility with f/i. Any suggestions?
Old 04-24-2011, 08:30 AM
bayer-z28's Avatar
Found a thread for ya,.
http://www.camaroz28.com/forums/showthread.php?t=554699
I figured it would loose power from the dropped c/r.... just don't mill them.. Apparently.
Old 04-24-2011, 03:14 PM
99 Blue Bird's Avatar
if u dont want to put the 853s on at least find some 241s for cheap. they are a little bit better. but honestly i would just keep the 853s on there until u go boost and than put the 317s on.
Old 04-24-2011, 07:27 PM
bayer-z28's Avatar
^ I was thinking something similar, but didn't know how OP's budget was. I am tossing around the idea of a 390 build next year and was thinking of doing my current 243 heads on it till I can get the funds for F/I and after I get that taken care of, I was going to get a high end set of ~72cc chamber heads to compliment everything and bump the compression back down to run around 18# boost.
Old 04-24-2011, 08:47 PM
boostnut's Avatar
Thanks for the tips. Looks like I'm going to grab a set of 243's for now & go to 317's at the time of turbo install. I should be able to sell the 243's later & get some or most of my $$$ back.
