bbk ssi manifold install
Old 05-11-2011, 09:20 PM
hfthe3rd's Avatar
Default bbk ssi manifold install
I'm installing this manifold this weekend and was wondering does it just bolt on our do I have to modify the coolant lines etc...
Old 05-11-2011, 11:57 PM
88gtman's Avatar
No modifications needed at all. Just replace the back valley cover bolt with the provided button head bolt and you will be fine. Should seat and fit like stock. Just installed mine about a month ago.
Old 05-12-2011, 02:21 AM
hfthe3rd's Avatar
Looks pretty man. So the manifold just laid on top of the lines and you didn't change anything ?
Old 05-12-2011, 10:50 AM
98ws6blk's Avatar
Be careful of the oil pressure sensor in back when you remove your old manifold. The hose going to the brake booster will hang it and break it. Trust me I know. lol
Old 05-12-2011, 04:47 PM
88gtman's Avatar
Yeah, despite being careful I broke mine too when trying to remove it. Best advise I can give you is to just buy a Sending Unit before you even remove the stock one. The years of the plastic being heated and cooled under the engine bay makes the plastic that much more fragile.
Old 05-12-2011, 07:57 PM
hfthe3rd's Avatar
Ok sounds good guys.
Old 05-12-2011, 08:12 PM
ODAWG's Avatar
Just remember to get some pieces of rubber hoses for the intake bolts in the back because they wont come out all the way because of the windshield cowl
,just in case you didnt know that already! Good Luck!
Old 05-12-2011, 10:40 PM
hfthe3rd's Avatar
What do you do with rubber hose? This is my first time doing a manifold.
Old 05-12-2011, 11:20 PM
Anthony Williams's Avatar
Slit 4, 1in. long 3/8 fuel hose to hold up the rear bolts while you jockey the intake into position as the back 4 bolts can't be installed with the intake sitting on the engine. The coolant lines need to be the LS6 2 plug in the rear with the crossover only in the front and button head or low profile bolts to secure the valley cover. Have fun.
Old 05-13-2011, 12:07 AM
garygnu's Avatar
you can tap down the ls1 colant lines to fit.or get a ls6 coolant line for the back and front .
Old 05-13-2011, 03:39 AM
hfthe3rd's Avatar
Hopefully taping down the lines work.
Old 05-13-2011, 04:02 AM
Blk2kSS's Avatar
I will be doing this aswell in the next couple weeks. Should I go ahead and get the LS6 coolant lines or stick with the stockers? I have a 2000.
Old 05-13-2011, 07:02 AM
Soul TKR's Avatar
LOL @ rubber hose
OR
You can just get some rubber bands and wrap one band around the head of each bolt opposite sides of each other. It's easy and holds them stationary out of the holes till you can pull the whole intake out.
Old 05-13-2011, 07:24 AM
SWEET98SS's Avatar
I just tapped mine down, worked great.
Old 05-13-2011, 08:20 AM
johnster's Avatar
is this intake as good as a fast intake went it come to hp?????
Old 05-13-2011, 08:50 AM
SWEET98SS's Avatar
Good reading here
https://ls1tech.com/forums/generatio...vs-fast92.html
Old 05-13-2011, 01:48 PM
hfthe3rd's Avatar
Did you just give them little taps and they went down the two holes?
Old 05-14-2011, 02:13 AM
99Bluz28's Avatar
Originally Posted by Soul TKR
LOL @ rubber hose
OR
Very true!
Just use some rubber-bands, works great!
Old 05-14-2011, 08:31 AM
kicksZ28's Avatar
Default BBK Intake
Had no problems installing mine. Broke the plastic piece at the back but had one on hand to replace it with. Also had to tap down one of the coolant lines at the back but other than that no problems.
Old 05-14-2011, 04:57 PM
HoLLo's Avatar
As far as what everyone is saying about the plastic oil pressure sender in the back. Go get an $8 socket to fit it, and remove it before the intake comes off.. It IS POSSIBLE to remove the sender before you take off the intake. I have done it several times. Save that $40
Quick Reply: bbk ssi manifold install
