Anyone running a P&P 85mm on an LS6 intake???
just like the title says, does anyone out there have this setup?......i know the P&P 80mm is made for stock intakes, but i'm looking to upgrade the stock TB to a P&P along with an 85mm Z06 MAF....I want to go as big as i can without spending too much $$$.....could i remove my LS6 intake and port match it to the 85mm TB with a dremel and just use RTV as a gasket?
i am running the FTP 98mm lid, to a 85mm vette maf to a PP 85mm TB,
i had my friend dremel out as much as he could from the ls6 and it matches perfectly
i went to my local hardware store, bought a gasket sheet( it was plastic, kinda like the original gasket, and used the tb spacer that comes with the PP tb and cut out a gasket
