coil power?
Old 05-21-2011, 09:40 PM
ls1f-body's Avatar
Default coil power?
I have a question about witch coil will produce more voltage. I have the stock coils off my 99 ls1 trans am and coils off a 6.0l out of a 2003 2500hd. wondering if the voltage is different for witch one I should use on my engine. Any help would be grate.
Thanks -Will
Old 05-21-2011, 10:02 PM
The Scammer Hammer
dr_whigham's Avatar
Melco's are the best. Part # 12558693. It's been tested and confirmed to have up to 5kv more secondary spark.
I believe 01ssreda4 has a set for sale right now in the classifieds......
Old 05-21-2011, 10:47 PM
Starz T/A 17's Avatar
I would assume they would be the same since there really isn't much difference between a 5.7 and 6.0. But honestly it really doesn't matter unless you are making a ton of power and then you would probable want to go aftermarket coils.
Old 05-22-2011, 01:05 AM
ls1f-body's Avatar
The part number on the coils off the 6.0 is 12558693, guess I should throw them on. thanks for the help dr_whigham
Old 05-22-2011, 03:57 AM
The Scammer Hammer
dr_whigham's Avatar
Here's a good thread on it from a while back.
https://ls1tech.com/forums/ls1-domes.../t-114249.html
I actually have a set that should be hitting my doorstep in a day or two. More power... people ask why? I say how about why not?
