Will an LQ9/LQ4 MAF work on an LS1?
Old 07-11-2011, 04:17 PM
venom 13's Avatar
Exclamation Will an LQ9/LQ4 MAF work on an LS1?
Like the title says, will an LQ9/LQ4 MAF work on an LS1? My friend needs a MAF sensor ASAP for an LS1 the he has in his 240sx, and I'm trying to help him figure out if he would have any problems using either an Lq4 or Lq9 MAF on his stock motor/stock ecu 2002 LS1. Quick replies would be appreciated.
Thanks
Old 07-11-2011, 04:19 PM
venom 13's Avatar
One other question he asked...does he need the IAT sensor for everything to work properly?
Thanks again fellas!
Old 02-14-2012, 02:46 PM
James Montigny's Avatar
Did it work?
Old 02-14-2012, 02:57 PM
1999BlueTA's Avatar
Yup it will work its an upgrade many have used including myself but will need 3 to 5 wire ls1 style adapter and will need to be rescaled for the particular vehicle!!!
Old 02-14-2012, 03:03 PM
1999BlueTA's Avatar
O ya I forgot its also larger than the stock 98-02 f body maf(75mm) its 85mm and has an iat built into it so you can use your existing one or buy the correct adapter thats wired for the iat intergrated in the 85mm truck maf!!!
Old 02-14-2012, 04:05 PM
Mine's going on a 93 firehawk (ram air) with an LS1 computer and a new build.
No matter what I do, it will be a custom mount and tune so it's no biggie.
Thank you for the info, I reworded my search and found plenty of threads.
I picked up a MAF and the adapter I needed.
I'll be sure to give the tuner a heads-up.
Quick Reply: Will an LQ9/LQ4 MAF work on an LS1?
