BBK Underdrive Pulley - Which belt?
Old 08-03-2011, 11:22 AM
Roxas's Avatar
Default BBK Underdrive Pulley - Which belt?
Hey everyone, I just picked up a BBK Underdrive pulley and was wondering which belt size it would require. I know the SLP Underdrive Pulley uses 2 different belts, but Im not quite sure about this one. I will not be running the BBK Underdrive Pulley kit ( http://www.ws6project.com/user_stor/...ve-pulley-kit/ )
I will just be using the crank/balancer pulley. Its alittle heavy, 11.5 pounds with tall walls. Thanks for the help!
Old 08-03-2011, 11:31 AM
Roxas's Avatar
Using search I found: https://ls1tech.com/forums/new-ls1-o...hat-belts.html
Serpentine belt: 19-760K6
A/C belt : 19-k04378
ARP Bolt : 12557840
Would this be correct? Granted the pulley mentioned in that thread is a PowerBond.
Old 08-03-2011, 03:18 PM
JKearney30's Avatar
According to the instructions on BBK's kit you need a 77" belt and a 37.7" belt (if you did use both)
The part numbers you would need in that case:
77" belt - k060770
37.7" belt - k040378 (this is actually 37.8" long but wont will be just fine.)
JKearney30's Avatar
http://static.summitracing.com/globa...s/bbk-1592.pdf
Here is the instructions for you.
Old 08-04-2011, 01:09 AM
Roxas's Avatar
77" belt - k060770
Thanks for the info! The K040378 should fit then, but Im still not sure about the K060770 since I am not using their alternator pulley.
Quick Reply: BBK Underdrive Pulley - Which belt?
