235 heads on ls1?
235 heads on ls1?
im thinking about purchasing a set of assembled heads and here are the specs, my question is are these specs to much for the cam i will have and mods i already have?
cam will be 224/224 .563/.563 112 LSA
specs on the heads will be
Assembled
64 cc chamber
235 int/ 87 ex runner
Angle plugs
2.080 int/ 1.600 ex valves
1.550 double springs
.700 max lift
Shaft mount
Standard ports
Fits Chevy LS 350 motors
mods i already have slp lid, 85mm throttle body, bbk ssi intake manifold, bbk long tubes, corsa catback with dmh cutout
Assembled
64 cc chamber
Angle plugs
.700 max lift
Shaft mount
Standard ports
Yep, thats a lot of head (no pun intended). Who made or ported them? I would try to contact them and see what their application was when designing the port work.
