Give me a list of everything I will need for fast 102 lsxr on ls1
I'm going to put on a 92mm tb and 102 lsxr intake on my camaro. What will I need for the install? Fuel rails, lines ect?
i did alot of research on these manifolds before i bought my 92/92. i remember reading without the use of an adapter to smooth out the flow between the tb and manifold numbers were off and idle is wacky. and 102 in just over kill for any street car. and you cannot use a stb. you do not need fuel rails or injector spacers. the rail fits perfect, fast told me it wouldnt but stock is on my car now. also i was able to squeese my accordian maf to tb tube over the 92 tb with 2 sets of hand and 3 screw drivers. one thing you should get though is some 1/8 inch rubber line incase you snap the vacume line on the passenge side as its like 6 inces away from where the stock one was. i shortened that hard plastic tube an put the factory rubber end back on and works perfect. also your going to have to bypass the coolant pipe through the tb as fast does not retain that feature. and im guessing you already have the oolant pipes for the ls6 inake but im not 100% on if ou need them bec i had them before the fast swap. and lastly the small allen head valley cover bolts o yea make sure you take the tape and clips off your knock sensor harness.
