Old 05-20-2016, 05:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
Fuel Filter, Check Valve
Old 01-08-2012, 11:57 AM
DBShocker's Avatar
Question Fuel Filter, Check Valve
ok i am looking to replace my fuel filter and fuel check valve and first just need to know where they are both located on a 98 camaro ls1 and what is the best replacement filters to get and where to get them also along with the check valve, thanks
Old 01-08-2012, 12:24 PM
LS1121's Avatar
Fuel Filter is under the car in front of the rear wheel on the driver side. Any auto parts store will have them.
Old 01-08-2012, 01:19 PM
DBShocker's Avatar
is there any real recommendation when it comes to fuel filter my car is dynoed around 430rwhp, just cam and minor stuff no turbo or anything or would just a regular one from autozone just be fine.
Old 01-08-2012, 01:48 PM
Rare96LT1Formula's Avatar
I personally run the AC Delco fuel filter. No problems with it, ever.
Old 01-08-2012, 05:04 PM
DBShocker's Avatar
do u have a link or part number for the ac delco filter? i found http://www.thunderracing.com/shop-by.../Fuel-Filters/
also need info on fuel check valve
Old 01-08-2012, 07:41 PM
LS1121's Avatar
Google Advance auto parts.....lol
Old 01-08-2012, 09:19 PM
DBShocker's Avatar
so does anyone have any idea on this fuel check valve tho?
Old 01-08-2012, 09:46 PM
chevymec's Avatar
The check valve is in the fuel pump asm.
Old 01-09-2012, 08:14 AM
Correct. OP- your fuel pump is inside of your gas tank if you were not already aware.
Old 01-09-2012, 11:09 AM
DBShocker's Avatar
lol kinda knew that part but thanks just wasnt sure if the check valve was under the car or inside with everything else i might have to replace.
Old 01-09-2012, 05:54 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Fuel filters are all pretty much the same. There's also a lot of re-boxed filters out there, you never know who really made it. It's not like oil filters which can vary in grade, quality and build greatly.
I always suggest a fuel filter change every spring time/once a year.
Of course, if you use cheep no-name gas you might want to change the filter more often.
Old 01-09-2012, 10:00 PM
DBShocker's Avatar
ok thanks well i went to advance auto today and got an acdelco fuel filter and seems fine, just my car still dosent like to start right sometimes, lol but that's all in another thread.
Old 01-10-2012, 11:11 PM
DBShocker's Avatar
i guess for my last question would i need to get a whole entire kit to do this job or just the pump its self for replacing my fuel pump?
http://www.racetronix.biz/itemdesc.a...PA-002&eq=&Tp=
or
http://www.racetronix.biz/customkiti...c=RFPK-002&eq=
Old 01-11-2012, 03:13 AM
1QUIKWS6's Avatar
I use the Racetronix in my 2000 WS6 and it has never let me down. Just bought the fuel pump and modded factory sending unit bucket to install myself.
I did the trap door mod instead of dropping the tank so access to FP is quick and EZ in the future.
Also a good idea to go with the FP Upgraded Wiring Harness that pulls power directly off the battery terminal on back of alternator, and at least an Upgraded Body Ground Kit (heavier gauge body ground wire to replace the weak factory ground wire) - if not an entire Big3 upgrade...
The upgraded FP wiring harness also has a pigtail to install a Boost a Pump if ever needed in the future to get xtra fuel needed for an added 100-150hp
Racetronix has the upgraded ground kit, Innovative Wiring makes a good Big3 wiring upgrade which would upgrade ALL your main power/ground wires.
And the modding/spending of cash never ends...
Old 01-11-2012, 06:37 AM
Paul Bell's Avatar
Agreed. Go with the Racetronix pump and wiring kit. The Innovative Wiring stuff looks pretty nice too.
Old 01-11-2012, 06:39 AM
DBShocker's Avatar
ok so i guess from what your saying http://www.racetronix.biz/customkiti...c=RFPK-002&eq= would be my best choice to get with all the extras with it.
Old 01-11-2012, 06:51 AM
Paul Bell's Avatar
Yep, that'll do ya.
Old 01-11-2012, 07:16 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Your best choice would be to buy the same stuff from Lonnie's Performance (he's a Racetronix distributor). His customer service is worth every penny if something goes wrong (and I've had personal experience with that one).
Old 01-11-2012, 04:14 PM
1QUIKWS6's Avatar
In addition - if you would prefer to have a fuel filter that has a replaceable filter element instead of buying an entire new filter every time:
I use a GM EFI Inline Fuel Filter from CM Filters #25-909-CM-15 for 93-01 Camaro/Firebird.
This inline filter is for GM EFI with quick disconnect 3/8" inlet and 16 mm female outlet port, is 4" long and comes with our 2-5/8" long 1 micron fuel element. CM EFI Fuel Filters are a perfect compliment to upgraded fuel pumps and the sensitive components of EFI systems. These filters out flow and have double the filtration of stock fuel filters.
https://www.cantonracingproducts.com...ion&key=25-909
Filter is $132, replacement synthetic elements are $14.40, & the seal kit is $9.60
Yes, it is definitely more $$ initially than a Delco filter, but I like the sturdy aluminum construction, the fact that it offers higher flow than stock filter, and double the filtration. After initial investment, cost to replace with fresh element is $25...
Old 01-11-2012, 04:18 PM
MeentSS02's Avatar
They even make a nifty billet aluminum mount for said Canton filter:
Quick Reply: Fuel Filter, Check Valve
