quick question
Old 01-19-2012, 06:32 PM
usnfenix's Avatar
Default quick question
so after a long tube install ( done several months ago) if i change the front o2 sensors ( used denso) but reuse the stock rear ones for the rear o2 sensors ( which i did ) will this cause the motor to constantly try and compensate for what it thinks is a deffective cat by adjusting A/F? im having a bad idle problem that is getting worse and was fixed my replacing my front o2 sensors ( used the stock ones right after the install) but now im having the same problem. i have another thread titled "idle issues getting worse" for more info if needed.
trying to see if a tune would correct my idle problem by deleteing the rear o2 and compensating for the lt and bbk intake install. as well as the AIR delete
Old 01-19-2012, 08:42 PM
joecar's Avatar
The PCM does not compensate for a bad cat.
You need some tuning for the LT's and BBK intake.
Old 01-20-2012, 07:39 PM
indianass's Avatar
definitely sounds like you need a tune of maybe clean your maf
Old 01-21-2012, 06:26 PM
usnfenix's Avatar
did clean my MAF today and no change
Old 01-21-2012, 06:52 PM
SKULL's Avatar
did you get the car tunned since you have done mods?
Old 01-21-2012, 06:57 PM
sepsis's Avatar
You need to tune after a header install?
Old 01-21-2012, 07:14 PM
usnfenix's Avatar
no tune yet
