Ground clearance with ARH longtubes and Strano springs/Koni SA's?
I'm thinking of swapping out my current stainless longtubes, which fit horribly, for some ARH longtubes and Y-pipe. Ground clearance has me a bit worried though. I have Strano springs and Koni SA's on all 4 corners. Does anyone have the same set-up so I can have an idea of what ground clearance will be like? I don't daily drive my car, so that won't be an issue. I also have my front shocks on the top perch and the rears do have the black donut shaped bushing installed. Any help is appreciated!
I'm running ARH 1 7/8" headers and catted Y with Strano's and Bilsteins. The drivers side cat is the lowest part of the system, but it all tucks up pretty well. Car is up in the air at the moment (and will be for at least another month), but if nobody else chimes in with pics I'll take some then if you remind me.
