Cut up harrness with pics!!???
Old 02-18-2012, 05:09 PM
trxman's Avatar
Default Cut up harrness with pics!!???
I have a 2002 Camaro SS m6 t-top. Built a ls2/ls3 motor for it and this piece of harness got cut off and I can't find where it came off the main harness. There are two 4 pin pigtails one female and one male. Male one is flat with only one red wire coming out and it's very small gauge it also fits in the altinator. The female square one has a lock and a mounting tab on it and looks like a O2 sensor. Theres also a ripped ground wire. Please help
Old 02-18-2012, 06:12 PM
sjsingle1's Avatar
hit the nail on the head......its the ground wire that bolts to the block...........the alt connector and the O2 connector......all are located right behind the alt
Old 02-18-2012, 08:27 PM
brooknasty's Avatar
I ripped the same ground strap. yep, longer connector to oxygen sensor, other connector is alternator, short wire ground goes above and a little forward of the long braided ground strap.
