02' Z28 Air Pump Check Valves Location???
Old 03-20-2012, 10:54 AM
fastazzls1's Avatar
Default 02' Z28 Air Pump Check Valves Location???
Hey guys can you tell me where the air pump check valves are located, can't find my manual to save my life. Also how much are the check valves and are they easy to replace. Thanks.
Old 03-20-2012, 01:14 PM
5.3LJimmy's Avatar
Those are built into the metal tubes that come off the top front of the exhaust manifolds on each side of the engine. Kind of hard to miss.
I'm not sure how much they cost but there are probably thousands of sets laying in peoples garages. It's one of the first things I permanently deleted from my car.
What makes you think they need to be replaced?
Old 04-04-2013, 09:07 AM
blue09rocket's Avatar
Mine need replaced too, I just recently threw a P1416 code, passenger side air check valve, might as well replace the drivers side while Im at it.
Quick Reply: 02' Z28 Air Pump Check Valves Location???
