Will LS7 ex. manifolds fit ls1/lq4
Old 04-16-2012, 01:50 AM
Vetteman61's Avatar
Default Will LS7 ex. manifolds fit ls1/lq4
Will these manifolds fit my 2003 Lq4. I'm putting it in a 1937 Chevy and I need some block huggers, but the stock ls7 manifolds are much cheaper to buy.
Any other reasons not to use the ls7 exhaust manifolds. I've tried searching everything I could find about them to get info. Does anyone have a measurement to how far they stick out from the block?
If not that, how far do the GTO exhaust manifolds stick out from the block?
Thanks,
Brandon
Old 04-16-2012, 01:55 AM
dodson55's Avatar
They will bolt on the engine not sure or the measurements I usually use f body manifold myself when I do swaps
Old 04-16-2012, 02:10 AM
bww3588's Avatar
Not sure if the ls7 manifolds will work, but ls2 and ls3 manifolds from a vette are the same design roughly and will for sure fit.
Old 04-16-2012, 11:09 AM
Vetteman61's Avatar
Ok, thanks for the replies, guys.
Old 04-16-2012, 11:13 AM
t/a98's Avatar
If you have some ls7 manifolds available I would try them, they flow amazingly. You would need the beginning of the rest of the exhaust though to mount to their oval exit.
Old 04-16-2012, 11:31 AM
Vetteman61's Avatar
I don't actually have any yet and I don't have any manifolds to test before I buy so I'm trying to make sure I buy the right ones the first time. (i have the old truck manifolds that I know won't fit).
There's a guy on a Vette forum that says he has some exhaust manifolds for a 99 C5. I've been measuring and it's just really hard to tell without holding them up to the car.
Thanks,
Brandon
Quick Reply: Will LS7 ex. manifolds fit ls1/lq4
