Ls2 heads
Ls2 heads
Aloha gang, are all ls2 heads a direct bolt on for 01 ls1 cars? Mines a 01 c5, might swap my lunati gold valvetrain to the 05 c6 ls2 heads off my friends 05 c6 and bolt to my ls1. My car already has a ls6 intake stock. I already installed a 235/245 duration 630 lift 113 lsa cam
If you are running the stock LS1 heads now, your PTV clearance is probably already really tight with that 245 exhaust duration. Going with any smaller cc head now might put you in trouble with clearance issues without "flycutting" the pistons. Flycutting the stock pistons is actually an easy task as long as you know what you're doing (do your homework) and have the right tools. I did mine last year (first experience flycutting pistons) and ended up being easier then expected.
