best bit for porting LS6 intake
Aloha gang, going to open up the inlet of my ls6 intake and put my ported 80mm BBK tbody on. Refining Friday. What's the best bit to use on the intake? And gasket sealer, red?
Like I said I wouldn't do this... But if you are try and get ahold of the gasket Professinoal Products supplies you with when you purchase the 80mm TB. it's a paper gasket that goes between the TB and the Adaptor... That will seal good. Ive seem them used when opening up the snout from a FAST78 to 85-90. Goodluck cousin
