A/C compressor removal and reinstall ???
Old 07-30-2012, 03:24 PM
3rdCoastPowerSports's Avatar
Default A/C compressor removal and reinstall ???
had to pull a perfectly good working a/c compressor from a vette in order to remove the motor. question is should i drain all the oil out of the compressor and put in new oil or should i just stick it back on, deep vacuum the system and add oil to the first charge? typically i add ester oil to the a/c compressor before i install them (rebuilt units that is). Just wanted some input
Old 07-30-2012, 04:53 PM
sjsingle1's Avatar
drain..........and flush
Old 07-30-2012, 11:34 PM
Thanks
