whining noise?
whining noise?
i had a noise that sounds like a bad belt so i replaced my serpentine belt on saturday and the sound went away but i know have a sound kinda the same but maybe a bad pulley what do you guys think anyone else had this problem? i really hate when my car makes noises
i may have an idea of what you are talking about...does it whine only when its cold outside?? i had that problem but only when i start up the car in cold weather. do a search i remember reading a post about it before.
Thats what it sounds like to me my 94 had a bad power steering pump whine especially when you got it under load but when i put the ASP pulley set on the whine went away its an expensive fix either way
i have the same problem
I have the exact same problem right now. i have a 98 trans am A4 and i replaced the serpentine belt to try to fix the noise. the noise is still thier but if i put belt drssing on it, the noise goes away temperarly. When i start the car i dont hear it and when its at idle its not noticable. but whenver i gun it or give it gas the whine goes louder and more annoying. i think its the pulleys and im taking my car in to have it checkedout by LS1-Speed. Im hoping its just teh idleler pulley or the crank pulley cause you have buy both tham in a set for aroun 200$.
the pullies you need are the tensioner pulley and the idler pulley from any auto parts store, should be somewhere between 18-30 bucks for the two of them together. seems the tensioner pulley goes out relatively quick. there has been a few posts about this same issue. i had a slight whine when i got the car at 38k miles. changed the serp belt and both pulleys at 40k miles and that took care of it. if i drive the car when its cold out (under 30 degrees) and the car hasn't had a few minutes to warm up it will still whine very slightly but once its warmed up...no more squeek or whine.
did you use teh dayco poly cog belt? mine would always slip and there is another part number for the dayco pm me if you'd like the part number from a non-sponser site. mine did the exact same thing even with the new pullies and i did find out it was the belt i was using too.
