Help, can i cut this tab off the block ??
hello all
what are the 4 tabs integral to the block casting, one on each corner ? the one on the P/S side front is tapped approx 1" deep.
i want to cut the rear one off, its just above the starter, i only need to cut approx 10mm deep of material off, if it can be cut i can route the steering column through which will solve major issues, i have attached a pic with the red arrow showing the tab im refering to
many thanks for any help you can give
cheers
Finlay
cheers
Finlay
