Would this hurt my heads?
I have a set of cnc ported heads and would like to know if it would make them flow more if I took a flapper wheel and smoothed them up more where the machine lines are on the intake ports?
Agreed, everyone thinks an intake port should be smooth which is just wrong, it the intake runner needs to be somewhat ruff to help with the A/F homogenization, if it is smooth the air/fuel will not mix properly and cause inefficient combustion. Basically unless you are a professional porter I would leave the heads alone.
