DynoMouth Install
DynoMouth Install
Here's my situation: I have SLP LM w/ LT's which sounds like ***. I was planing on removing the peice that has the resonator and taking that along w/ the bullet to a muffler shop to have them weld it up for me. The problem is my LM system is welded together I've started tearing everthing apart so I can get a tail pipe cutter by the weld above the axle, but am getting pretty irritated. Does anyone know if the bullet can be installed w/ the system still on the car???
I really hope it can, I'm about to take my loaner tail pipe cutter back to autzone and jam it up that retards ***
LS1TECH Sponsor
should be able to no problem just bring the shop your car and the new bullit at worst they'll unbolt it from the y and tilt it then have plenty of room be like a 30-45 min job tops and will sound much better
Well, I got the 18" Dynomax bullet installed today. Quited down quite a bit w/ the cats on. Took them off and it's still a bit raspy around 2k. Much better though I'm sure I'll just change my driving habits a little bit to stay out of the raspy r's. Sounds awesome at WOT though.
