ASP Pulley questions/possible issues?
Hey guys! I am going to have my ASP Pulley installed in a few days. I have a 2001 WS6 M6 with Lid, GMMG exhaust, Jet Hot LTs and catted Y pipe. Now my question is, will this pulley cause any issues with my car? I have heard of voltage problems and such from these things? I just don't want to have bad driveability because of this. Also, do any of you guys know what belts, or belt part # I need for the ASP Crank Pulley? Thanks a lot guys!
I had only one issue with mine, and that was with the alternator pulley being too tall and walking the belt off. I put the stock alternator pulley on, and all has been well.
As for belts...
http://www.aspracing.com/frame.htm
As for belts...
Thanks for that info! I got another question though. Will I need a new crank bolt for the asp crank pulley? What size do I need, and where can I get it? Are these available at Napa or autozone? I need it by tomorow morning, thanks a lot guys!
As far as charging problems, you shouldn't have any as long as you're not running a hefty stereo system. I see that you're an M6 also, so you shouldn't even really notice a difference in your car. You also can't re-use the stock bolt as it is torque to yield, but you can pick up another one from your local dealer. Part number is 12557840.
Alright guys, I found the belts at autozone, but I can't find the crank bolt for anything. I went to autozone and napa and they said they don't carry them. I then went to the dealer and they said they didn't have any in stock and it would take a few days to get it in. I don't know where else to go? I was going to have it installed tomorow along with my LTs, but I guess I'll have to change my plans unless I can get some more ideas on where to get it. Where could I get a new crank bolt to be used with my ASP pulley? Thanks guys!
