Ribbed side of belt running on water pump pulley?
Has anyone ever tried to run the belt with the ribbed side (rather than the flat side) on the water pump pulley?
My setup that i'm thinking of will work much better this way but i'm wondering how quick it'd wear out the belt, if at all?
Cheers!
Cheers!
BUT if you just change the belt routing to the other side of pulley the pump will rotate in wrong way. I dont know if there are different rotation pumps for LS motors.
