Water Pump Bolt
Water Pump Bolt
What size is the bolt the secures the thermostat housing on the LS1 water pump? There are two (2) of them and I stripped one of them and need to heli-coil it.
What size heli-coil does it take?
Cheers!
Chad
Cheers!
Chad
Thanks man, is this the right Heli Coil kit to repair it?
http://www.helicoilchart.com/helicoi...r-kits-metric/
Chad
Chad
The pump is used but I rebuilt it, its a Meziere electric pump and I replaced the o-rings and had it painted, I also sent the motor back to Maeziere for a free motor/pump evaluation. It's installed on the motor but luckily the stripped bolt is on the top / outboard side so I can get to it fairly easy.
Thanks for the help bro!
Chad
Chad
