head and cam gasket kit help
i have looked all over and seen all kinds of gasket kits the most popular seems to be the one from texas speed for about 160 dollars does this kit
http://texas-speed.com/p-173-basic-h...asket-kit.aspx have everything i need to swap out heads and a cam. I have also seen this one on ebay but wasnt sure about it
http://www.ebay.com/itm/99-01-CAMARO...a11f58&vxp=mtr
I just want the best kit for the value to do a head and cam swap i noticed alot of kits dont come with an oil pan gasket which i heard i need.
The Victor Reinz kit from the seller on ebay works well, although I got the kit without the head bolts. I had a set of ARP head bolts that I used.
It had a bunch of stuff I didn't use though (ie throttle body gaskets, exhaust manifold collector gaskets - because of Longtubes, egr and air gaskets - i deleted them at the time of the head swap)
Also didn't mess with knock sensors or the valley cover so didn't use those gaskets either.
Also I only did my heads, not heads and cam so your going to need all the gaskets associated with the cam swap.
So i would think that the Texas Speed kit would be better for you as it has those gaskets and parts.
i seen the victor kit was normally good but what other gaskets would i need for the cam swap. i would really like the full kit if they sell one. I will prolly have to just call tsp
