ls1 wants to accelerate and drive itself at low speeds
Hey guys im tring to finish up my ls1 swap on my 89 firebird and im having an issue with the car wanting to drive itself. It was doing this before and after lmr tuned it and was hoping getting it tuned would take care of it. A few seconds or so after letting off the brake at idle it would begin to accelerate up to 30mph and drive itself down the road. Iam right now taking off my intake and checking for leaks and resealing everything. I have noiticed that there are divets on the bottom of my fast intake from my arp head bolts. Any input would be greatly appreciated.
Here is my set up:
rebuilt 98 ls1 short block
prc ls6 stage 2.5 heads
Tsp torquer v2 cam 112lsa
Fast lsxr 102/102
4l60e
circle d 245mm 3200-3400 stall torque converter
01 fbody pcm
Here is my set up:
Fast lsxr 102/102
4l60e
01 fbody pcm
Check for vacuum leaks and check for throttle position signal to be showing 0% when you aren't on the throttle.
My guess is a vacuum leak and I am surprised it wasn't noticed during the tune. If it is a leak, you will want to have the tune looked at once it's fixed.
Another possibility is that the converter is too tight for the combo. What is the idle RPM set at?
Thanks for the info, ill let you know what i find when i get it back together. Ill also note that when i was taking the intake out i noiticed that lmr drilled a hole in my throttle plate and neglected to ask or tell me about it.
if you can't get the RPM down by locating any vacuum leaks or pin point the source of the problem try to plug the throttle body butterfly plate breather hole with a rivet. My setup pulls more air that i want which causes my rpm's to be a bit higher thus making the car accelerate a bit, once i plug the throttle body plate hole with a rivet problem solve. RPM's are at normal settings and everything running beautiful.
Also not sure which intake your running but if you got an EGR check the EGR tube that inserts on top of the intake right behind the throttle body. The EGR gasket might of moved and its sucking in air. Just a thought as i'm not sure what intake your running.
If so follow my previous post and its fixable with a large rivet (one that fits perfectly within the hole)
The intake i have is the fast lsxr 102 intake and i have the 102 tb. no egr. the throttle body didnt have a hole in it when i took it to lmr but it had one after i got it home and took it apart ( had to clean up the burs from where they drilled). Thanks for the tip on the rivet. ill see what i find when i get it back together
thats what im tring to figure out. lol When i was there on the first day they said the iac was being intermittently inconsistent and the motor would want to idle up and then catch itself and would want to stall
i wish i could tell u what lmr did but they didnt really give me to much info on the tune and there wasnt really anyone there to answer my questions when i picked the car up. I talked to a Patrick Guerra and he tried to explain to me about some of the tables that need to be adjusted for idle. Im sorry i cant be of anymore help with the tune info as this is still new to me since im coming from a 350 tpi to a ls1 im still learning
Here is my set up:
Fast lsxr 102/102
4l60e
01 fbody pcm
Here is my set up:
Fast lsxr 102/102
4l60e
01 fbody pcm
Did everybody miss that part? Your head bolts shouldnt be contacting any part of your intake, So I assume your speaking of the valley cover bolts. You need low profile bolts so that they don't contact and CRACK the bottom of your fast intake. Which it very well may have already or they could be keeping you from torquing the intake down properly and getting a good seal.
Alright, so I got home from work today and finished hooking everything up. I rechecked everything one more time and it looks all good. I got my Dakota digital tach interface today and I got that hooked up and programmed. Started the car up and it started idling. My dad said it was idling kinda high. If the tach was reading correct than it was idling at 1500 rpm. Won't know how accurate it is till I get a scan tool that can read live data. Haven't blocked the hole in throttle body yet so that may be y the idle is so high and the tune is probaly more than likely off
Update!!! I trailered my car to Victoria to have Patrick gurrea take a look at the tune and it was off. Patrick took the time to redo the tune and get it right. I'm very pleased with the results and can't wait to get it redynotuned after getting the motor a little more broken in. Thanks everyone for your input and advice.
