Meziere water pump accessories help needed..help please.
Well i bought a meziere electric water pump (street with idler) from a member and its on the way here. Can anyone tell me what i need to install on my Z28 exactly? I know ill need some hose adapters but not sure which ones. Anything about thermostat housing? Will the belt stay stock size? Any and all help is GREATLY appreciated so i can get what i need ordered for quick install. Thanks
belt should stay the same size. the hose adapters for the heater should be on the pump. You will also need a sbc thermostat which can be bought anywhere and it will need a 3/16 hold drilled into it to allow water in when the thermostat is closed to cool the pump. other than that you just need to wire the pump to a relay that comes on with the key and hook the main power from the relay to the battery post or fuse post to ensure it gets a full 12v
Here's the install sheet.
http://www.meziere.com/images/produc...tion/WP319.pdf
More install info.
http://www.ls1howto.com/index.php?article=26
More install info.
