True Duals with Magnaflow 10416 Bullets?
Just wondering if you guys can comment on how loud this setup would be I have a 228r cammed 5.3 and dual magnaflow 10416 bullets. I plan on running the mufflers with turn-downs dumped before the Axle. Do I need to run an X-Pipe? Will it **** off neighbors. I am trying to avoid RASP at all cost!! Which sounds better X pipe or H pipe. I want a deep tone.
The H vs X pipe argument has no end.I've had a h, now an x. Both equalize exhaust flow, but the X is marginally better for power. H makes a little deeper sound, X is a little more raspy, but also cut down on my interior resonance In my particular combo. Many late model mustangs come with an x-pipe, which contributes to their sound. Last I noticed, Nascar used an x-pipe on their unmuffled side exhaust because of the better scavenging effects.
Many other factors of course contribute to overall sound besides muffler type & pipe diameter Like tailpipe exit location,exhaust tip type, etc. Stainless also sounds a little more tinny than aluminumized steel.
You can buy or make either type of crossover.
Outside of packaging resrictions there is really no reason to go with an H over an X. The power difference is not drastic, but it exists. Why leave something so simple on the table. Rasp should be a non-issue with a good dual setup. Any cammed/LT/Bullet setup will be loud, just no way arounf it.
