meiziere install snag
well i installed the pump and used jmx's website. i hooked up the trigger wire to the big grey wire under the fuse box in the vette. didn't work. so i used a pink wire and it worked. so when the keys on the pump is on. thats ok with me. then the pump still wouldn't work. so after fartin around checkin stuff for an hour, i found a bad ground location i selected. i moved the wire to a better ground and the pump worked. so check those grounds!
