Vacuum hose routing? w/ Aftermarket VC (pics)
Been searching around on how the vacuum hoses are routed on the engine for my swap. Found a few pics but none on my application. I have the GM Performance aluminum valve covers with no PVC holes just the oil cap one where I put a mini K&N. Also I have no break booster. I have the LS6 valley cover with the hose that runs to the intake figured out, thats about it. To what do I route the TB one and the one behind the intake? (map sensor area)
On that not anyone know where to route the 97-98 fuel rail regulator/ dampener hose to?
any help appreciated
Thanks
Thanks
Here's what I did with my throttle body...
https://camaroversion20.shutterfly.com/329
https://camaroversion20.shutterfly.com/329#328
The pipe will pull out of the throttle body, Then I taped threads in it and used a Allen head bolt with some red RTV silicone.
Ports 1,2, and 4 are now just vacuum sources. If you need to run any vacuum operated items you can plumb them in to any one of those 3. If you don't need them plug them off. You can go to any auto parts store and they should have an assortment or rubber caps to block them off.
