Coil Issues (passenger side not firing)
Old 03-06-2014, 12:21 PM
ATX LSX's Avatar
Angry Coil Issues (passenger side not firing)
Did a coil relocation, extended coil harness.
First issue was driver's side wouldn't fire due to INJ1 fuse being blown (passenger side fired at the time). Fixed that, now passenger side isn't firing.
None of the cylinders on passenger side are firing, manifold is entirely cold.
Checked wiring, it's good. Fuses are good.
WTFBBQ...
Anyone have any suggestions?
Old 03-06-2014, 12:29 PM
Burken01's Avatar
What year car?
Sometimes the coil harness can get flipped upside down and cause misfiring, no firing!
Old 03-06-2014, 01:06 PM
thunderstruck507's Avatar
are you getting signal pulses at the coil harness and individual coils?
Old 03-06-2014, 01:11 PM
ATX LSX's Avatar
it's an 2001
Old 03-06-2014, 01:13 PM
Burken01's Avatar
Check and make sure the harness is oriented in the right direction, pic 1 is the right way
Attached Thumbnails Coil Issues (passenger side not firing)-image-1949608329.jpg   Coil Issues (passenger side not firing)-image-1111801706.jpg
Quick Reply: Coil Issues (passenger side not firing)
