A/C pulley making noise, what is the cause?
Old 03-06-2014, 03:31 PM
Tzone21's Avatar
Default A/C pulley making noise, what is the cause?
I recently replaced a bunch of pulleys when I did my heads/cam swap. Now theres a squeling noise coming from the a/c pulleys(brand new belt). Its very loud on a cold start but dims down a bit once warmed up. The noise is there all the time no matter if the air is on or not. Is the problem a bearing or my a/c clutch rubbing? Thanks
Old 03-11-2014, 09:16 AM
IIILuisIII's Avatar
Mine was doing the same thing last summer with a new belt also. i replaced it with this and all was good.
Amazon.com: Goodyear 4040410 Gatorback Poly-V Belts: Automotive Amazon.com: Goodyear 4040410 Gatorback Poly-V Belts: Automotive
Old 03-11-2014, 02:54 PM
Dainius56's Avatar
I had same issue and it was compressor regardless of being engaged. Just got mad of hearing it until I cut the belt off. Replaced compressor and all is well. Here's to hoping that's not your problem.
Old 03-13-2014, 01:38 PM
Tzone21's Avatar
Originally Posted by IIILuisIII
Mine was doing the same thing last summer with a new belt also. i replaced it with this and all was good. Amazon.com: Goodyear 4040410 Gatorback Poly-V Belts: Automotive
So your noise would ease up a bit once warmed up? This belt may be worth a try
Old 03-13-2014, 01:40 PM
Tzone21's Avatar
Did you ever open up the compressor to see what is was or just replace it? About how much did it cost to replace?
Quick Reply: A/C pulley making noise, what is the cause?
