could low oil level make starter continue to run
So before, everything worked normal. Then all of the sudden on cold starts my starter continues to run. It's never the same amount of time either. Sometimes it's for one minute, sometimes up to 3 minutes.
But once the engine is warmed up, if i crank it the starter cuts off immediately. Nothing has changed, no new work done, nothing electrically has changed. The only thing i noticed is the oil level was super low. I refilled it and it cut off line normal but also it was still fully warmed up so i don't know if that fixed it
