Need help rewiring MAP sensor plug
Hey guys. I recently started swapping out my LS1 intake for an LS6. I thought I had everything unplugged so I pulled the intake out. Once it was out, I noticed the MAP sensor plug was still plugged in but the wires were completely pulled out of the plug. I'm just curious in which order the wires were in the plug and what's the best way to make sure the wires are in the plug completely and don't risk them coming loose once installed.
Thanks in advance for any help/info!
Best way is to order a new plug with pigtail, solder and heat shrink the wires together. Here is one for you.
http://www.currentperformance.com/Co...s/LS1_LS6.html
Awesome, thanks so much!!
